sonda
Executing inline powrshell script
In the installer, we have inline PowerShell scripts. Now our company introduced some new policies and installers are restricted and PowerShell scripts are not executed. Antivirus is detecting and blocking. Is it possible to change the execution path for the inline script not to be executed in the temp folder (to configure some other location that from AntiVir is permitted)? Any suggestion how to avoid this? It's somehow configurable from advanced instaler. Installer is digitaly signed?
Any suggestions are welcomed.
Regards
Re: Executing inline powrshell script
We already have on our TODO list an improvement regarding this behavior.
Unfortunately, for now, I'm afraid I am not aware of any workaround for this.
sonda
Thanks for the reply i was thinking that upgrading to 18.1 and signing the scripts will help, i just upgraded local version but sill same behavior.
Regards
Yes, unfortunately the behavior is the same even when signing the script.
I will update this thread once the improvement will be added to Advanced Installer.
This improvement has been added in version 20.0 of Advanced Installer, released on October 18th, 2022.
