Cvsschaitu
Repackagercli build option
Tue Apr 20, 2021 8:38 am
I have repackaged vscode.exe 1.53 to msi.
Can I use same rpk to create msi for vscode.exe 1.55 version via cli?
And how to build msi with rpk via repackagercli as we have build option in repackager UI.
Thank You.
Re: Repackagercli build option
Mon Apr 26, 2021 5:29 pm
You can try to use the "/ImportRepack <source_file_path>" command in order to import captured results from a previous repackaging operation into an Advanced Installer project.
However, depending on the changes the version 1.55 brings, I'd say it would be better to repackage it separately.
This can be done by adding one more line to your script, e.g.:
AdvancedInstaller.com /edit MyProject.AIP /ImportRepack C:\MyRepackagingResults
AdvancedInstaller.com /build MyProject.AIP
