aalyam
Choose value in xml and put in registry
Good day. Is it possible to implement this scenario:
There are 2 msi files (opentextenterprisescan.msi + plugin.msi)
After install opentext enterprise scan, users can import configurations from xml-file (img.1). User can choose configurations only needed for him (img.2). It creates registry key in HKCU (img.3)
But I need to create this reg-keys in HKLM.
I created exe project with 2 chained packages in AI. And I create dialog window with checkboxes where users can mark the required configurations
How to bind checkbox property with value from xml file? And how based on the user's choice, add the required registry value to HKLM?
Re: Choose value in xml and put in registry
It is not quite clear to me through what is the user importing the configurations from the XML file? Is it through another application?
This could be done by adding the XML file in your Advanced Installer project (in the Windows Installer format) and then condition the installation of the node using the checkbox. For instance, let's consider the following XML file:
<note>
  <to>Everybody</to>
  <from>Catalin</from>
  <heading>Reminder</heading>
  <body>Don't forget me this weekend!</body>
</note>
You can condition each node (e.g. the "to" node) based on whether the checbox is checked or not. This way, the final XML file will only contain the settings selected by the user in your dialog.
aalyam
Catalin wrote: ↑Wed Apr 28, 2021 5:37 pm It is not quite clear to me through what is the user importing the configurations from the XML file? Is it through another application?
the user imports the configuration in the installed OpenText Enterprise Scan application: Tools-Import Confuguration
cmdline: C:\Program Files\OpenText\Scan\bin\ScanCfgFromFile.exe "<full_path_to_xml>" {true|false}
I see, so the import is done through a custom tool.
To be fully honest with you, I do not really see an easy way to achieve this.
Assuming the XML file is delivered with the setup package, you can try to create a custom action that will import the XML elements based on the user's choice in your custom dialog.
Due to the fact that the custom action is reliant on the XML file, it should be scheduled after the "Add Resources" action group with its' execution time being "When the system is being modified (deferred)".
Hope this helps somehow!
aalyam
1. may i use checklist instead checkboxes?
2. I can set a condition for a registry key as a component. how to set a condition for a registry branch.
Sure!
The CheckList control is a regular list box with check-boxes.
For more information about a listbox, please refer to the following article:
Working with Windows Installer ComboBox and ListBox controls
I am not quite sure I understand what you want to achieve here. Could you please give me some more details?
aalyam
i decided not to use xml
I imported in AI project the HKLM registry branch from a workstation with a software product installed. For each profile i created a new Feature.
Also I created a checklist.
During installation, the user selects the desired profile from the checklist. In accordance with his choice, the required registry branch will be added to HKLM. But I didn't understand how to set the list of values ​​for the checklist and what condition to use for the Feature.
aalyam
I did it successfully.
1. is it possible to make the selection of the value from the combobox required?
2. how to pass multiple selected values ​​from checklist to combobox? I get one value with commas
To do so, you can select the "Next" button in the dialog containing the combobox control and set two "Control Events", as it follows:
Condition: COMBOBOX_1_PROP = ""
Action: Disable
Condition: NOT COMBOBOX_1_PROP = ""
Action: Enable
Where COMBOBOX_1_PROP is the property assigned to your combobox control.
This way, the "Next" button will be disabled until the user will select a value from the combobox.
Here, please note that in order to add multiple values to a combobox, you will need to use the "|" separator, e.g.:
Set Installer Property
Property: AI_COMBOBOX_DATA
Argument: COMBOBOX_1_PROP| Value1| Value2
This is also explained in the 3. Populate ComboBox and ListBox controls article.
By default, a checklist control (the one you are using) will save the values selected by the user at install time in a property, separated by a "," character.
Basically, let's consider a checklist control with the following elements in it:
Text: Element1
Value: Value1
Text: Element2
Value: Value2
If the user select both of these at install time, the property assigned to your checklist control will look as it follows:
Property: CHECKLIST_1_PROP
Value: Element1, Element2
If you populate the combobox using the CHECKLIST_1_PROP property's value, even though it contains more items, it will be added as a single element to the combobox, as in your screenshot.
Based on the article I have give above, if we want to insert multiple items into the combobox control, we will have to separate the items with the "|" character.
The easiest way to do so would be to set the "|" as the separator for the checklist control (the comma "," is the default separator):
This way, the items will be added separatly to the combobox control.
However, please note that a drawback exists for this method - that being if the user, for instance, forgets to add an element and has to go back to select it. If this is the case, the combobox will already contain some elements and the populate will fail due to two elements having the same value, e.g.:
If the user selects only Element1, this will be added. Now, if the user goes back and selects Element2 as well, the custom action will try to readd the Element1 element, resulting in an error because that element already exists.
This can be avoided by adding the "DeleteFromCombobox" custom action as a "Published Event" for the "Back" button.
More information about this in the "Delete items from ComboBox and ListBox controls" article.
Additionally, for your reference, please find attached a sample project in which I have showcased everything said above:
Sample Project Combobox.aip
(23.8 KiB) Downloaded 1254 times
Hope this will help!
