lcdiet.net
Put .mdb files in the documents folder of the target pc.
Fri Apr 30, 2021 3:13 pm
Hi, I distribute software that I would like to upload to the windows store. I am creating an msix package I have three myprog.exe mydb files. mdb myimg.jpg myprog must find the software in a folder. I chose documents when with Advanced Installer I put in document under userprofile after installing I cannot find the mydb.mdb file in the documents folder. How can I fix since the windowsapp folder is inaccessible?
Re: Put .mdb files in the documents folder of the target pc.
Tue May 04, 2021 2:22 pm
All MSIX packages have a predefined install location where the OS extracts the resources, the location being:
%programfiles%\WindowsApps
As you have mentioned, this is a system location that, by default, is inaccessible from Windows Explorer.
For more information about this, please have a look over the following:
MSIX - Install Location
Even though the files are installed in %programfiles%, the MSIX is actually installed per-user, not per-machine.
For more information about this, please have a look over the following article:
AppData Management in MSI/MSIX/APPV
Hope this will help shed some light over this topic.
