taran1392
Change in Custom Action script is not getting reflected in the new build
Sat May 01, 2021 2:53 pm
I added a inline powershell script custom action called updateEDRC. I have been making changes in the script .But it is not getting reflected in the new installer build.
I have even deleted the custom action, but still that custom action is executed in the new installer build.
I have attached setup logs and project file.
EDRCSetup.log
(419.72 KiB) Downloaded 102 times
EnsureDRController.aip
(77.43 KiB) Downloaded 114 times
Re: Change in Custom Action script is not getting reflected in the new build
Tue May 04, 2021 5:52 pm
If possible, could you please give me some more details about your scenario?
For instance, what changes have you made that are nto reflected in the new installer?
Instead of simply building your project, could you please try to "Rebuild" (near the "Build" button --> click on the drop-down arrow --> "Rebuild") and let me know if this helps?
