Eternal21
'Run PowerShell Inline Script' can't access temporary files
I've got the following custom action called: RunInstallScriptInline
It runs a powershell script that sets up self-signed certificates, website and app pools. In order to set up certificate I need to pass a crt and pfx files to it. I was trying to do it using temporary files, as following:
-rootCaCrtPath "[&rootCA.crt]" -rootCaPfxPath "[&rootCA.pfx]" -rootCaPfxPassword '[pfxPass]' -siteName 'my.site.net'
But the project builder complains right away. In fact you can't even browse to temporary folder location. This seems to work fine if you 'Launch a file' instead of 'Run PowerShell Script Inline'.
I even tried the following, which got around builder errors, but didn't work during runtime (the installer couldn't find the temp files at the location specified)
-rootCaCrtPath "[TempFolder]rootCA.crt" -rootCaPfxPath "[TempFolder]rootCA.pfx" -rootCaPfxPassword '[pfxPass]' -siteName 'my.site.net'
What am I doing wrong? For the time being my workaround is just including the crt, pfx files in the project output folder:
-rootCaCrtPath "[#rootCA.crt]" -rootCaPfxPath "[#rootCA.pfx]" -rootCaPfxPassword '[pfxPass]' -siteName 'my.site.net'
The problem with this approach is that I don't want those files on the system after the install is done (hence why I wanted to use temporary files in the first place). How can I remove the files, if temporary files are not supported by inline scripts.
Re: 'Run PowerShell Inline Script' can't access temporary files
I have ran a few tests on my end and it looks like you indeed can not pass the path to a temporary file, at least not in the "regular" way (i.e. entering "[" in the field --> "File" --> select your temp file).
However, every temporary file has a property assigned to it that stores its' path and that should do the trick for you.
Eternal21
The workaround works. Thanks.
I am glad to hear it worked.
