SimHorizon
AppId?
I'm deploying a .NET WPF application and using the Update Installer option. In the "Notification" section of my Update config file there is an option to "Enable notifications":
Per documentation it requires a "AppId" entered in my Advanced Installer project:
By default this is blank ... where does this value come from? Reading Microsoft's AppId documentation suggests this is a GUID. I can generate a GUID (all upper case) and enter it here, but will that work for Advanced Installers "Notification" process?
Cheers, Rob.
Re: AppId?
Hello Rob,
My colleague Dan has created an article regarding this new specific feature of our Updater tool.
For more information, please refer to the following forum thread:
Send custom notifications in Windows using the Updater
In the above article, the AppId concept is also explained.
Hope that will help!
SimHorizon
Re: AppId?
Thanks for the response.
I'm a little confused by that article:
1. Expiration Date? Documentation says "The notification expires the day after the date specified." Is this so that I can setup a future date to display a notification message?
2. The AppID in your example has path information in addition to a GUID ... how can there be a hard coded path when users can configure their own installation paths during install of my app?
3. Is Image URL, Link, Link Button Text required?
4. If the notification is clicked on, does it launch the updater in standard mode?
Cheers, Rob.
Re: AppId?
Hello Rob,
The "Expiration Date" simply means the notification will no longer be displayed after the specified date.
The "AppID" field is of formatted type, meaning you can use properties instead of a hardcoded path.
For instance, both "Caphyon" and "Demo App" can be seen in "Product Details" page. The properties that store those values would be [Manufacturer] and [ProductName].
No, those fields are not mandatory.
Hope things are clearer now!
SimHorizon
Re: AppId?
Excellent, thanks Catalin.
Cheers, Rob.
Re: AppId?
You are always welcome, Rob!
