vpodans
Windows Service properties during product upgrade
My product includes a Windows Service to install with some default settings (actions, user account, etc.) when new service is installed.
Product upgrade to to version consist of "Remove previous version and install new version":
To my knowledge, the service will be removed upon uninstall and reinstalled again. However, administrators may use custom account and settings during application usage which I shall not overwrite upon product upgrade. Is there a way to prevent service removal/reinstall if I'm doing an upgrade? I prefer to uninstall the service only when I decide to uninstall the product completely?
Re: Windows Service properties during product upgrade
You are indeed right, the service will be removed and reinstalled upon upgrade.
I believe the best approach here would be not deleting the service (i.e. unchecking the "Delete" option from your service's control operations). However, please note that will also affect the normal uninstall. In this case, I'd say we could have a custom action that removes the service only during uninstall.
vpodans
Thanks Catalin,
sorry for late response. Your answer confirms my concern.
but won't this action execute during upgrade and cause same effect -- service is removed and all custom settings are gone as well?
You are always welcome!
We can condition the custom action to only be executed during a regular uninstall through the Upgrade Options:
For instance, if you want the custom action to be executed only during uninstall, you can leave only the "Uninstall" and "Regular Uninstall" options checked.
vpodans
Thanks, I will take a look into this option and let you know with outcome.
vpodans
Just a follow up. It seems this doesn't work. Even making suggested changes, installer overwrites custom settings on a service.
In order for me to further investigate this, could you please create a sample project that reproduces this issue and forward it to me by e-mail at support at advancedinstaller dot com? Here would be the files I need:
- the sample .AIP file
- a download link for the setup
- a test-case which I can follow in order to reproduce this (here, I am mostly interested in the custom settings I can do for your service, so I can check those before and after upgrading)
