divyaniP
Disable Repair not working
hello, support
I want to disable the Repair option from the control panel.
I have gone through https://www.advancedinstaller.com/user- ... s-tab.html
I have disabled here
Still, I am getting the Repair option on the panel.
How to disable this?
I have attached screenshots for reference.
Re: Disable Repair not working
The "Disable Repair" option only affects the control panel applet.
According to the following StackOverflow thread:
Removing Install/Repair Option From MSI file Context Menu
1 ) if you right-click the msi after you have installed the program, it displays the context menu, providing you Install/Repair options...
and the answer:
Don't try to solve #1. To do this you would have to break the registration for all .msi files on the machine in question, and no end user should have to put up with an application breaking their machine.
It looks like it is not recommended to do that.
