repack2021
Create mst with new files in cab
Mon May 10, 2021 12:22 pm
So, I have the same problem as discussed here, from 2016. viewtopic.php?f=5&t=31807
I need to create a MST File for a vendor msi, add a few custom config files to it. What I want to come up with, is the original MSI, a new CAB-File containing only my additional files when saving the mst.
Here´s how I´m doing:
1. Download Java 8 update 291 exe-file from https://www.java.com/en/download/manual.jsp
2. Start the exe and copy out the msi from AppData\LocalLow\Oracle\Java\jre1.8.0_291
3. Create a new mst with Advanced Installer, point to the Java msi.
4. Add a file to the Java install folder.
5. Goto Builds, mark "MSI with resources next to it"
6. Choose Advanced CAB layout
7. Go to Advanced Layout tab, check that your added file is resided in Cab2.cab. Check that "Include CAB into the MSI database" is not selected.
8. Mark Cab1.Cab (with installer.exe) and select the "Include CAB into the MSI database".
9. File, Save as.(whatever name)
No new cab-file is created for only the added file.
Is this how it´s suppose to be or is it a bug? (again)
Advanced Installer 18.2, Architect version.
Windows 10.0.18363.1500
Re: Create mst with new files in cab
Mon May 17, 2021 3:21 pm
I have tested this scenario using the provided steps and I was indeed able to replicate the behavior you described.
Unfortunately, I can not say for sure why this happens.
I have forwarded this to our development team for further investigations. I will update this thread once I will have more information about this.
Mon May 17, 2021 3:41 pm
Could you please proceed as it follows and let me know if everything works as expected:
- on your disk, please create the following folder:
DISK1
- add the MSI you have extracted to that folder
- recreate the transform & build it
repack2021
Tue May 18, 2021 10:47 am
The DISK1 workaround works! Thank you!
I hope your developers can check what´s wrong and maybe we´ll get an updated version of Advanced Installer later.
Thanks again
Tue May 18, 2021 11:56 am
I am glad to hear everything works as expected now.
