nursultannd
TeamCity Plugin
Hello! I am using Advanced Installer to make my installer project. So, I decided to automate this process via teamcity. And I downloaded advanced installer plugin for teamcity. And it appears at plugins window, however in doesn’t appearing in add-build step window.
Can you help me?
Re: TeamCity Plugin
I have run some tests on my end and everything worked as expected - I was able to select Advanced Installer as the "Build runner type".
After adding Advanced Installer plugin, you are asked if you want to enable it:
Could you please make sure that the plugin is enabled? Perhaps a server restart might help here.
The above was done on a clean machine where I have just installed TeamCity and added the plugin to it.
nursultannd
Re: TeamCity Plugin
Hello Catalin!
I have resolved my issue, the problem was in the way of downloading a plugin. I have copied plugin files from git. not from the official releases page. The instructions I think are not clear enough. I hope your company will review the instructions to download TeamCity plugin.
Nursultan
Re: TeamCity Plugin
Hello Nursultan,
I am glad everything works as expected now.
I am sure this will be of help for further users facing a similar scenario.
