Justin
Update failed because it reboot pc during installation.
Tue Jun 01, 2021 4:55 am
We using updater.exe to upgrade application, but sometimes will happened reboot pc during update installation. So it failed to update.
Could you help about this? Thanks!
The update log shows :
RESTART MANAGER: Will attempt to shut down and restart applications in no UI modes.
Transforming table Error.
Best Regards,
Justin
Re: Update failed because it reboot pc during installation.
Thu Jun 03, 2021 7:08 pm
Hello Justin,
Please note that the respective message does not mean a PC reboot, but rather a restart of the applications.
That is usually encountered when a file that is to be updated is kept in use by a process.
For instance, let's say a configuration file that is kept in use by an executable is scheduled for update. In order for the update to be succesfull, the EXE file must be stopped so it does not keep the file in use - because the file can not be removed that way.
Justin
Sun Jun 06, 2021 2:37 pm
Hello Catalin,
Thanks a lot!!
Best Regards,
Justin
Mon Jun 07, 2021 4:29 pm
You are always welcome, Justin!
