Tony86
Re-populate databases into Combo Box after incorrect credentials
I'm using SQL Database Browse functionality to populate a combo box when it is pressed. Similar to what's in this post
It is working as expected when authentication information is correct.
Problem is when user typed in incorrect credentials, pressed the combo box, met with the error dialog, typed in the correct credentials then pressed the combo box but nothing happened. I guess it is due to Windows Installer not automatically refresh combo box control without switching to a different dialog as stated here.
How can I make it to repopulate databases into the combo box after user has corrected the credentials information?
Another question: When executing ShowDatabases with incorrect credentials, user is met with error "ODBC Connect: timeout exceeded." instead of something like "Login failed for user ..". Is there a way to have it display the correct error similar to when using the "Test Connection" button ?
I'm using AI 16.7 Architect.
Tony
Re: Re-populate databases into Combo Box after incorrect credentials
Hello Tony and welcome to our forums,
This could be done by adding a "Refresh the current dialog" event on the button that executes the query for the databases, i.e.:
It is indeed true that the given message may not be the most helpful for a first time user, but I'm afraid it may not be possible to change it since it is given by the ODBC driver itself (it is not a custom message).
P.S.: Regarding your first question, are you by any chance trying to connect to MSSQL databases? If that is the case, please note that you could use the "SQLServerConnectionDlg" dialog. This is a custom dialog that we have created, specifically for SQL Server (not for MySQL), that does every configuration autoamtically (i.e. database browse, server browse, etc.). In the screenshot above, I have used that dialog and the refresh event is added automatically.
Tony86
Thank you for your response.
I'm using SQLServerConnectionDlg and I can do like your instruction.
My question, however, is how do that without using the "browse" button. Please see my attached screenshot below.
I think I got it.
P/S: After testing I think I'll have to go with the browse button like you did. The reason is that with my setup the databases list is only populated once. If the user sees the list of databases then realizes that he needs to look up in another server then there is no way to force the dialog to repopulate database list.
Hello Tony,
I understand your scenario now, but yes, as you have mentioned, I believe it would be best to use the "Browse" button, as it is by default.
