PhilippeG
MaintenanceTypeDialog incorrectly painted
Sometimes the MaintenanceTypeDialog is incorrectly painted
See the picture
Re: MaintenanceTypeDialog incorrectly painted
Hello Philippe,
This might happen if the "Enhanced User Interface" option is only taking effect during the install.
Please go to "Themes" page --> "Settings" tab and make sure the "Enhanced User Interface" is set to "Always (install, uninstall and maintenance)".
PhilippeG
Sometimes, it appens even the "Enhanced User Interface" is set to "Always (install, uninstall and maintenance)".
Best regards.
PhilippeG
Re: MaintenanceTypeDialog incorrectly painted after patch
I have more information :
The problem appends only after installing a patch.
Note after installing a patch : The variable [AIEXTERNALUI] is empty.
Have you a solution?
Best regards.
Hello Philippe,
I have already answered a similar thread you have created here where I have explained why the two options are not compatible:
AIEXTERNALUI empty during patch
