There are two scenarios I can think of:
- you do not have administrator privileges. Please note that administrator privileges are required in order to create a folder under
C:\ProgramFiles folder
- you install a 32-bit setup (
"Install Prameters" page -->
"Package type" being
"32-bit") on a 64-bit machine and the
"Program Files" folder from your project is resolved to
"C:\Program Files(x86)" at install time.
In addition to the above, you have also tried to recreate the path in your project under the "Program FIles" folder, i.e.:
- OfficePath.png (16.54 KiB) Viewed 10122 times
The second scenario is highlighted in our
Paths of the folders in the "Files and Folders" Page article as well:
- ProgramFilesFolder.png (69.91 KiB) Viewed 10122 times
If that is the case, please use the
"Program Files 64" folder from your project instead or change the
"Package type" to
"64-bit".
