sonda
There is a problem with this Windows Installer package .. on upgrade
I have an installer with a custom action that lunching cert until and installing some pfx certificate.
If you doing the first install (on your machine there is no other installation) installation will be smooth without any errors, but if i change the version and make a newer version and try to update the older version already installed i receive error:
the certificate is a temp file. and execution of custom action is set after resources are available. Advanced installer is 18.2
Not sure why on first install execution of custom action is ok, but when doing an update of application trows error.
I have attached example .aip (in the zip, there is also cert and dummy file)
repro steps:
1.From the aip create installer
2. install software
3. Change version in Product details in aip file
4. generate new installer
5. run new installer to update previous version
Any suggestion are welcomed
pfx.zip
(6.54 KiB) Downloaded 601 times
Re: There is a problem with this Windows Installer package .. on upgrade
Hello Sonda,
The custom action is failing because it can not find the specified file. The reason for this is the fact that the temporary file is removed during the uninstallation process of the older version.
In order to avoid this behavior, you can set the following condition on your temporary file:
NOT UPGRADINGPRODUCTCODE
The above condition should be set in both the older and the newer versions (e.g in the first version 1.0.0 and in the next version 1.0.1).
sonda
Thank for response, I will try this
You are always welcome!
