nchounlapane
Post-Install pre-requisite unable to run SQL inline script
Advanced Installer 16.7
Enterprise
I have a post-install prerequisite that has a custom SQL connection that runs several inline SQL scripts. Running the main install followed by the post-install prerequsite runs normally as expected but when running via basic install, the post-install prereq cannot connect to the SQL database. Within the logs, I get the following error:
CREATE DATABASE permission denied in database 'master'
Process of the install:
1. Execute Main install with the following command:
.\program.exe /qb /passive
2. After main install finishes, it passes [SERVER_PROP] into the post-install prereq's Install Command Line (Basic UI)
3. Post-install prereq starts
4. First custom action sets [SQL_AUTHORIZATION] to the following:
Uid=localuser;Trusted_Connection=yes;
5. Second custom action sets [SqlConnectionString] to the following:
Driver=[\{]SQL Server[\}];Server=[SERVER_PROP];[SQL_AUTHORIZATION]
6. Post-install prereq should execute SQL scripts as expected
Troubleshooting:
-Ensured that the Local sys admin account has sufficient privileges to create databases in SQL
-Ensured that installs work on Full UI installation
-Attempted on Advanced Installer 18.3
*One other thing I came across is when calling [LogonUser] resulted in SYSTEM instead of the current user so I had to explicitly set Uid=localusername.
I have sent a sample project to the support email with subject line as the same name of this post.
Re: Post-Install pre-requisite unable to run SQL inline script
Hello Nicholas,
Could you please try to check the "Impersonate User" option and let me know if that helps?
You can find the option in your prerequisite project --> "Sql Databases" page --> "Impersonate User" (on the ribbon).
nchounlapane
I apologize for the super late response. Our main installer does have Impersonate User, but it looks like the sample project I've sent you guys doesn't have that enabled. We figured out that there were some missing parameters that were not set and eventually figured out what was going on. Thank you for the response.
Nick
You are always welcome, Nick!
I am glad you guys were able to find the culprit!
