jcouturier
APPDIR empty in custom actions powershell
Thu Jul 01, 2021 7:15 pm
When i execute custom actions (powershell), appDir variable is empty.
Can you tell me what's wrong?
Thank you.
Contact:  Website
Re: APPDIR empty in custom actions powershell
Fri Jul 02, 2021 6:59 am
Hi and welcome to our forums,
Can you please send us the .aip (project file) and a debug verbose log of the installation by email at support at advancedinstaller dot com so we can investigate them?
You can create an installation debug log by launching your setup package with a command line like this:
msiexec /i setup.msi AI_DEBUGLOG=1 /L*V installLog.txt
when using an MSI package type, or a command like this
setup.exe AI_DEBUGLOG=1 /L*V installLog.txt
when using an EXE package type.
