SimLoe
Setup requires Internet conection if I add an prerequisite
The following now happened twice and we had to publish an emergency update because users were complaining and AI didn't notify us:
Create a new sample project, don't add any prerequisites. Go to Launch Conditions. The checkbox "Run only if an active Internet connection is found" is unchecked.
Go to the prerequisites page, add Visual C++ Runtime as a prerequisite. Select: Include offline page
Go to Launch Conditions. The checkbox "Run only if an active Internet connection is found" is checked.
Expected behavior: If I select "include offline package", setup should not add the "internet connection" checkbox without telling me anything.
Either there has to be a warning, or the checkbox shouldn't be selected at all.
Re: Setup requires Internet conection if I add an prerequisite
Hello Simon,
That option is indeed checked automatically just in case the user presses "No" when asked whether he wants to include the prerequisite or not in the setup.
However, please note that Advanced Installer should notify you about that:
Beside the "Notifications" tab, a message should appear where the "X" is, i.e.:
Are you not getting this notification when adding the prerequisite to your setup?
SimLoe
Hello Catalin,
you are right, I tried again and saw the notification. However, I didn't see it twice before and it disappeared quite fast. Still, it doesn't make sense to me that you are adding this option even though I am choosing "no". I could only understand this behavior when I selected "yes", but maybe this is due to technical limitations.
Thank you for clarifying this.
Simon
You are always welcome, Simon!
