PepperLen
Prerequisit of Python not quiet
Hi All,
have a "little" problem with prerequisite of installing python silent? Do you have any idea. Tried a lot of version and checked the syntax but the setup from python 3.8.6 is comming up after the bild and want, that the user don´t have to check the path ... many thanks
Re: Prerequisit of Python not quiet
Please note that the three fields from under the "Install Command Lines" are related to the UI level of your main setup.
For instance, the parameters you try to pass to the Pyton installer will only be passed if the main installation is also run silently.
If you install the main setup with full UI, please copy the parameters and input them in the "Full UI" field.
In addition to that, please remove the "python-3.8.6-amd64.exe" part, as that is not necessary. In those fields you only need to pass the parameters for the installation.
PepperLen
Hello Catalin and all,
many thanks for the welcome. Thank you for the reply. I changed this but there is no effect ... the same is from loading direct from url ... have no more ideas
thanks if have anyone a hint for me
Marcus
PepperLen
if i make a custum action, is the same and the dialog is comming up completely ...
PepperLen
hi all,
found a solution that will work. Help came from this: http://wp.kraeftigerkaese.net/pub/pytho ... all-w-xml/
With an unattend.xml works
Hello Marcus,
Thank you for your followup on this and for sharing your solution with us!
I am glad you managed to get it working!
