tudor
Drop down for certificate store empty
My issue is related to the one discussed here: viewtopic.php?f=2&t=45471#p116504 - I was, however, unable to make it work.
I've generated a cert using OpenSSL and added it to the store (cert has a validity of less than 5 years - as per the discussion in the other thread):
Screen Shot 2021-07-13 at 11.16.18 am.png (24.15 KiB) Viewed 5499 times
Then went back to the project and the cert was not in the drop down:
Screen Shot 2021-07-13 at 11.16.46 am.png (24.04 KiB) Viewed 5499 times
I'm using the latest version of AI.
Any help would be greatly appreciated.
Thank you,
Tudor
Re: Drop down for certificate store empty
Hello Tudor and welcome to our forums,
As per the following article:
Settings Tab
Certificates from both "Personal Store" and "Trusted Root Certification Authorities" store are imported in "Use from certificate store".
Previously, as it is also mentioned in the post you have linked, we used to check more stores. However, we recently reduced the searched stores to only the two mentioned above.
