Kratzer
AI 18.4 Crashes when using old caches
Hi guys,
after switching to new 18.4 installer version all projects are crashing in ide (and jobs from jenkins) when building (not rebuilding) projects created with earlier version. Rebuilding project is successful.
After removing all cache directories existing from old builds with older versions of AI (17.8 / 18.11) everything is working properly.
Bernd
Re: AI 18.4 Crashes when using old caches
Hello Bernd,
I have tried testing this on our end, but I can not replicate the described behavior.
If possible, could you please give me a test-case which I can follow in order to reproduce this on my end so I can further investigate the behavior?
Kratzer
I created simple msm project with AI 18.1.1.
To reproduce the problem:
- Download attached file
- Unzip it
- Load project with AI 18.1.1 --> build and rebuild are working properly.
- Load project with AI 18.4 --> build (not rebuild) results in error --> AI runs into a problem with exaclty the one I described.
- Removing that cache folder resolves the problem.
Hopefully it helps.
Bets regards and thank you,
Bernd
test.zip
(70.69 KiB) Downloaded 757 times
Hello Bernd,
It looks like this issue has already been reported by our QA team a while ago - I just found it in our bug tracking tool.
I will update this thread when a fix will be available.
Kratzer
thank you, additional comment, problem is existing in latest version too.
Bernd
Hello Bernd,
Unfortunately, the issue has not yet being fixed.
I will update this thread when it will.
The only solution for the moment would be removing the cached folder as you have described above.
Hello Bernd,
This has been fixed in version 19.8.1 of Advanced Installer, released on August 17th, 2022.
