aaronclawrence
Certificate from system path
Hi, I'd like to change the certificate our AIP uses to sign, to load it from
%APPDATA%\Microsoft\SystemCertificates\My\Certificates\filename.pfx
There seems to be no way to specify this in the AIP editor though?
Re: Certificate from system path
Hello Aaron,
Are you not able to specify the path by using the "Use file from disk" option?
This should allow you to pick the certificate that will be used to sign, no matter its' location.
