b.eggers
Missing old version while updating to new product version
Hey!
We are building our product-setup using advanced-installer 17.8. On several clients, we get the following error-message,
while updating our product to a newer version:
If we click on ok, the setup abords with an error message, that uninstalling the product failed.
If we want to install an update, we need to remove all registry keys manually first.
Re: Missing old version while updating to new product version
Hello Benedikt and welcome to our forums,
By the looks of it, I am assuming you are trying to apply a patch.
This may happen if when the patch is applied it needs to access a resource from the CAB. Please keep in mind that at install time Windows Installer caches the MSI installation database in the "Windows\installer" folder, but it stripes down the CAB within the MSI (for size reasons). Then, during the repair operation if a resource from the CAB it's required Windows Installer will prompt for original setup installation.
If your target installation setup is an EXE setup, in order to avoid this problem, you can select the "Do not delete extracted MSI and CAB files" option from "Builds" page -> "Bootstrapper Options" section.
Please let me know if this helps!
b.eggers
Thanks for the fast answer!
We are building two targets:
1. MSI for Active Directory deployment
2. Exe with embedded MSI
The error message also occurred, if I uninstall our product first and make a new installation. So not only in the "patch" case.
EDIT:
I think most of the time this problem occurred when using the msi/AD setup.
Thanks a lot!
Hello Benedikt,
I do not really see how you can get this error in an upgrade scenario (remove the older version & install the newer version).
In order for me to further investigate this, please forward me the following resources:
- a copy of the .AIP file used to build the older MSI
- a download link for the older MSI
- a copy of the .AIP file used to build the newer MSI
- a download link for the newer MSI
- a copy of your patch project
- a download link for the patch (.MSP file)
- a step-by-step test case which I can follow in order to reproduce this on my end
by e-mail at support at advancedinstaller dot com.
So far, I can see that you are trying to install the MSI on a Windows Server machine, from a network location.
b.eggers
Hey Catalin,
I will try to prepare all information for you. A few facts:
1. No, I did not try to install it from a network location. The setup is just search at that location. Maybe an older version was installed
from that location.
2. When I uninstall the product and take a look at the registry, a lot of keys are still existing. After I remove them manually, everything works as expected.
3. Computers which are only using the .exe setup, are working fine.
Thanks a lot.
Hello Benedikt,
I will be waiting for the resources and I will start investigating this.
If possible, could you please also add the uninstall log (verbose) to the resources, as I want to check something in it regarding the failure to remove the registry keys? More information about how to create a log file in our "How do I create an installation log?" article.
