janisito
.NET Framework run time version used by custom action
Hi!
When I use a C# custom action written by myself, under which .NET Framework run time version will the custom action be executed? Is this decided by AdvancedInstaller or can I choose it myself by modifying the CustomAction.config file? I want the custom action to be run under v4.8.
Thanks.
Regards
Jan
Re: .NET Framework run time version used by custom action
Hello Jan,
I believe the custom action will use the runtime you specified in your Visual Studio project's properties.
If you right click on your project in Visual Studio --> "Properties" --> "Application", it should specify the targeted framework, i.e.:
janisito
I tried to verify the runtime version by logging the following property to the log file:
AppDomain.CurrentDomain.SetupInformation.TargetFrameworkName
but it returns an empty string when run from the custom action. Normally when run from a console application it returns what .NET Framework version it is using. Not sure why that is or if there another way to verify the actual runtime version used. I have indeed set my custom action project to use .NET Framework v4.8 but I'm not sure it is enough.
Regards
Jan
Hello Jan,
If you have specified the target framework in your custom action, I do not see why it would use another version, as long as the targeted version is installed on the machine.
In the following Microsoft article:
Framework targeting overview
it is specified that:
In Visual Studio, you can specify the version of .NET that you want your project to target. Framework targeting helps guarantee that the application uses only functionality that is available in the specified framework version. For .NET Framework apps to run on another computer, the framework version that the application targets must be compatible with the framework version that's installed on the computer.
janisito
That makes sense. Thank you for resolving.
Regards
Jan
You are always welcome, Jan!
