ipollock
Applications and Virtual Directory showing root folder IIS
1. Built an installer for web applications.
2. Builds and installs fine
3. When i examine the IIS Tree on the left i see that the root folder containing apps (In file explorer) are also showing up as a virtual directory.
So in file explorer i have stored all the applications in 'WebAppRoot' as sub folders. When i create these in the IIS tab in Advanced Explorer
they look fine. Once this is installed into IIS, all of the applications show up ok as expected but the 'WebAppRoot' folder is also showing up
as a virtual folder even though it is not designed to be part of the IIS tree.
Can anyone tell me what i'm doing wrong? ;)
Thanks.
ipollock
Re: Applications and Virtual Directory showing root folder IIS
Is this because the application folder is also the root folder? If so, how would i get around this - i've also tried having an empty folder alongside but both are brought into the IIS tree...
ipollock
Ok, so figured this out - it was in the documentation and a little bit of trial and error. You have to set the install condition to (NOT Installed) for the root
and the rest goes in ok.
Hope this can be useful for others.
IIS-Setup-Don't show root folders.PNG (22.77 KiB) Viewed 32751 times
Thank you for your follow up on this and for sharing the solution! Certainly this will be useful info for future customers!
