a.varantes
Silent installation CMD, new version with specific feature trouble
I've an installation with several features.
I can install (new installation) the software without any problems using the command line
My.exe /exenoui /qn /L*V "c:\logs.txt" FEATURE1="true" FEATURE2="true"
When I've a new product version and a older version installed on a machine with all the features installed, my command appears to be not working.
If I run the CMD, the older version is uninstalled correctly but my new installation appears to "don't care" about my specific features (FEATURE1="true") to be installed and installs all the features anyway.
If I run this from the EXEUI it only installs the specified features but by CMD it doesn’t work.
Any help with this, many thanks!
Re: Silent installation CMD, new version with specific feature trouble
This is happening due to the "MigrateFeatureState" action, whose purpose is to take the state of the features from the old package and transfer that to the new package.
In order to avoid this, please proceed as it follows:
In the newer version of your project:
  1. Go to the “Upgrades” page.
  2. Check the “Customize Advanced Installer upgrade rules” option from the “Application Versions” section.
  3. In the "Upgrades" table, double click on the upgrade code which has the property set to "OLDPRODUCTS".
  4. Select the “Upgrade Action” tab and uncheck the “Enable Migrate Features action” option.
Hope this helps! If you have any other questions please don't hesitate to contact us.
a.varantes
Hello, liviu.
Thank you for your answer, we've already made the change and now everything seems to be OK.
Best regards
You are always welcome, Antonio!
We are glad everything works as expected now!
Please let us know if there is anything else we could help you with and we will be glad to assist.
