tn8826
MSI does not start because of "Program Compatibility Assistant Service"
Hello all,
Have anyone here encounter an issue where when double clicking on the install msi, the program doesn't start, doesn't respond.
Then, checking the task manager, there is a process "Program Compatibility Assistant Service", closing this process allow the msi to proceed. If I tried to start (double clicked) the msi multiple times, nothing will happens but after the "Program Compatibility Assistant Service" is terminated, multiple instances of the installers started.
It doesn't happen on all systems that we have but happened on our QA's machines. It is not consistent every time but maybe 1 out of 4 times on his machine.
Does anyone have any idea?
Thanks very much for all the support,
Tuan
Re: MSI does not start because of "Program Compatibility Assistant Service"
Hello Tuan,
To be fully honest with you, I have never encountered such a behavior in the past, nor did I have a user encountering this.
The "Program Compatibility Assistant" is a component of the Windows OS and we do not have much "power" over it.
Perhaps you could try running the MSI in compatibility mode (assuming this is somehow related to the "Program Compatibility Assistant" service) and see if something pops-up.
Hope this helps somehow!
tn8826
I'll try your suggestion. It is a strange and random behavior.
Tuan
You are always welcome, Tuan!
Please let me know the outcome of this.
