BlackSwallow
how to return all search result in file search opration
hello again to firends .
i used this topic to search a folder http://www.advancedinstaller.com/forums ... 202#p84666
but result is incomplete ... means :
suppose i have three folder with same name (TestFolder) in three different location ...
1 ) c:\newfolder1\TestFolder
2 ) c:\newfolder2\TestFolder
3 ) c:\newfolder3\TestFolder
but result contatin only c:\newfolder3\TestFolder
how can i get all of them ? in folder search opration
Re: how to return all search result in file search opration
In order to achieve that, I believe the best approach would be to have 3 different searches, since each "TestFolder" is in a different location.
Could you please give me some more details about why you would need to have all three results in one search?
BlackSwallow
thanks ...
i installed 5 metatraders in my windows and i want install my experts in all of theme .... the metaquotes expert path is something like below :
[AppDataFolder]\MetaQuotes\Terminal\(32 Characters ID)\MQL4
i want to get all five IDs with searching MQL4 Folder but i receive Only one of them and i need all of them to install my Expert on them ...
can you help me please ?
Even though the folder has the same name, since the location is different, please note that we will need to create a separate search for each folder, e.g.:
As you can see in the above screenshot, a search is needed for each ID.
If you want to have all the results in a single property, then a Custom Action might be required, although I believe it would be better just having a different search.
