AI_New_User
Error says cannot find path, but I know the files and paths are there
I know the following exists: full install of the exe, the patch, the updater config file, and the updater exe. So I'm not sure why I'm getting this error?
Re: Error says cannot find path, but I know the files and paths are there
The "System can not find the file specified" is a system error. See the System Error Codes article.
I am not quite able to replicate the behavior you described.
In order for me to further investigate this, could you please please send me the following resources:
- a copy of your old .AIP file
- a copy of your new .AIP file
- a download link for the old setup package.
- a download link for the new setup package.
- and the Update Configuration Project file.
by e-mail at support at advancedinstaller dot com so I can further investigate them?
