tiffanym
User Profile - Powershell
I brought this up in a private email conversation, but thought I would list it here as well.
Is it possible to add an option for a pre-defined folder to a user's home directory when using powershell? In the GUI the "User Profile" is part of the pre-defined folder paths (https://www.advancedinstaller.com/user- ... paths.html) but in the API it is not listed as an option (https://www.advancedinstaller.com/user- ... lders.html)
Thanks!
Re: User Profile - Powershell
Hello Tiffany,
I have tested this and it indeed does look like this is not currently supported.
Most likely, this is due to the fact that we recently have added the "User Profile" folder and we did not update our PowerShell Automation support accordingly.
I have now added this on our TODO list of improvements and hopefully this will be added in a future version of Advanced Installer.
tiffanym
Great, thanks!
Hello Tiffany,
You are welcome!
As a followup to my last thread, this will most likely be available in the next release of Advanced Installer.
From what I could see, we already had it on our TODO list of improvements and it is under testing right now.
Hello Tiffany,
This improvement has been added to Advanced Installer 18.7, released on September 21st, 2021.
Return to “Feature Requests”
