the gridlock
Build exe without manifest question?
Hi admin,
Long time no see. My question is related to vsto.
Can I build the C# program without the manifest file?
How should I set up the project so that the product information is minimal.
Thanks you!
Re: Build exe without manifest question?
I am not quite sure how to achieve that, but I found the following article from Microsoft:
Manifest Generation in Visual Studio
which I believe you will find useful.
the gridlock
Thank you.
I found this: https://stackoverflow.com/questions/666 ... t-manifest
but it's not clear to me.
can you show me how to remove manifest file via custom app.config? (I'm using vsto .net)
Unfortunately, I am no expert in this subject either.
I have tried to havea look right now and I have found the following:
- open your VS solution
- right click on your project --> "Properties" --> "Applicaiton" tab
- under "Icon and manifest" --> "Manifest" --> click on the dropdown button and select "Create application without a manifest"
the gridlock
Thank you.
I will try to solve it.
You are always welcome!
