Tatyana Mykhnevych
Kaspersky Anti-Virus issue on application installation
My Advanced Installer version is 18.6.
I call installation from my custom code with /qn parameter for installaing updates.
When intallation is run the following error occures: The following applications should be closed before continuing the install.
When installing the same application not from my custom application (but by clicking .exe) and without /qn flag no issues occur.
What is the reason of Kaspersky error exactly in this case and is it possible to avoid it?
Tanya
Re: Kaspersky Anti-Virus issue on application installation
Hi Tanya,
I’m not really sure why this happens.
Please note that this dialog "FilesInUse" is shown automatically by Windows Installer, therefore it cannot be removed or hidden. This behavior appears when the installation/uninstall process tries to install/remove files that are used by other processes.
After the update is downloaded, can you please try to manually launch the setup package from an elevated command prompt using the /qn parameter and tell me if the same problem happens?
mysetup.msi /qn
Tatyana Mykhnevych
Running from cmd with /qn passed without problems.
Hi Tanya,
This is quite strange.
In order for us to further investigate this issue, can you please send us the .AIP (project file) and an installation log when this problem happens by email to support at advancedinstaller dot com?
Please generate the log from your custom code using a command like this:
setup.exe /qn /L*V installLog.txt
I suspect the file in use behavior occurs because the Anti-Virus scans in real-time the files of your application from the disk and has a handle in one of the files you are trying to overwrite by installing the update.
As a workaround, you can try to contact your Anti-Virus vendor about how to whitelist your setup package.
Tatyana Mykhnevych
Thank you for your advice, will try to contact Anti-Virus vendor and check logs.
You are welcome!
