Tatyana Mykhnevych
Internet prerequisites are not installed for Windows 7
My Advanced Installer version is 18.6.
We use prerequisites downloaded from the internet for Windows 7. They are downloaded but not installed. Errors like on attached file occur.
There is nothing useful in log file (just Doing action: FatalError).
Could you please assist? How can I find an actual error? This error happens not depending from install conditions because when the same prerequisite is not downloaded from Internet everything works fine.
Tanya
Re: Internet prerequisites are not installed for Windows 7
Hi Tanya,
I've tested your scenario, but I cannot reproduce the behavior.
Can you please send us the .AIP (setup project) file and an installation log by email to support at advancedinstaller dot com so we can further test and investigate this?
You can create an installation log by launching your setup package with a command line like this:
setup.exe /L*V "C:\installLog.txt"
Tatyana Mykhnevych
Hi Liviu,
Thanks for your reply.
The problem was in prerequisite link for MariaDB. Https certificate for this website was not valid for windows 7.
Tanya
Hi Tanya,
Thank you for your follow-up on this. I am sure this will be of help for further users facing a same scenario as you.
I'm glad you solved the issue.
Please let us know if there is anything else we could help you with and we will gladly assist.
