HobartSimms
Command Line, prerequisites, and cmd_line
-cmd_line <cmd_line>
An optional command line for launching the prerequisite. This parameter cannot be used with OpenSite option.
This may get a bit confusing, but I'm trying to build with Jenkins what we have always done manually through the GUI.
Here is the issue:
I need to mimic this when using the -cmd_line option.
Any ideas on how I can do this for all three scenarios as depicted above?
HobartSimms
Re: Command Line, prerequisites, and cmd_line
Looks like I was mistaken on the capabilities of the command line. From what I can tell, It does not have the ability to generate user defined prereqs. I'm not able to find any documentation anyway if it can.
I am not quite sure I fully understand what you want to achieve here.
If the "cmd_line" parameter is used, all three fields will be updated with the provided command line, just like in your screenshot.
Could you please give me some more details about what you mean by this (maybe exemplify)?
