Hirnschwamm
Language selection combobox has white font on light background in "Air" theme
when I choose a theme from the "Air" family and include a language selection dialog in the EXE bootstrapper (via Translations -> User Interface Language -> "Display language selection dialog") the text in the combobox that is used to select the language is in a white font on a light gray background, making it quite hard to read. Is this by design or rather a bug? Is there a way to fix this?
Version of AI is 18.7.
Thanks in advance.
Re: Language selection combobox has white font on light background in "Air" theme
Hi and welcome to our forums,
I have tested this and I can confirm that this indeed is a bug on our side.
I have forwarded this to our development team and this will be fixed in a future version of Advanced Installer.
As a workaround, you can go to the "Table Editor" page, select the "BootstrapperUISequence" table and modify the sequence of these actions like this:
Hope this helps! If you have any other questions, please don't hesitate to contact us!
Hirnschwamm
Hello Liviu,
thank you for the quick support and the workaround. It works well :)
Best regards
Hirnschwamm
You are welcome, Hirnschwamm!
I am glad everything works as expected now.
This has been fixed in version 19.0 of Advanced Installer, released on December 17th, 2021.
