maxeineder
Windows Defender detects virus when executing a setup built with AI
we have been building our installer with AI for several years. Since last friday, Windows Defender detects a virus when the installer is executed, see screenshot. It is Uwamson.A!ml in two ps1 scriptfiles. We checked our installer project, but we don't include any powershell scripts, so they seem to be generated by AI. We use AI 18.6.1.
Is this a known issue?
Max
Re: Windows Defender detects virus when executing a setup built with AI
Hello Max,
This is quite strange. I'm not really sure why this happens.
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
SimLoe
A similar behavior was reported today by one of our customers. When he is running our setup, the following warning occurs:
Can you please have a look at it?
Hello Simon,
This issue was due to a false-positive detection of our PowerShell scripts.
We have submitted this for whitelisting to Windows Defender and they whitelisted it.
Here would be their reply:
We have removed the detection. Please follow the steps below to clear cached detection and obtain the latest malware definitions.
1. Open command prompt as administrator and change directory to c:\Program Files\Windows Defender
2. Run "MpCmdRun.exe -removedefinitions -dynamicsignatures"
3. Run "MpCmdRun.exe -SignatureUpdate"
Could you please let your user know about updating the malware definitions on his machine and then let us know if everything works as expected?
SimLoe
Hello Catalin,
our user is using McAfee VirusScan Enterprise - maybe you should tell them as well to whitelist this behavior. I will ask him whether he is using latest definitions.
Hello Simon,
We already did that.
However, unfortunately, we have not yet gotten any answer from them.
I will update this thread when we will.
