AI_New_User
How to update an already existing aip?
I have a project / aip already. But I want to --through PowerShell-- update the version number, product code, and the files (that will go in appdir).
I have this code:
$advinst = New-Object -ComObject AdvancedInstaller
$project = $advinst.CreateProjects(“enterprise”)
$project.ProductDetails.Name = "Existing Project"
But this seems to be for a brand new installer, not an existing one.
Is there a full example of how to update an existing aip?
Re: How to update an already existing aip?
You need to use a command like this:
$advinst = New-Object -comobject AdvancedInstaller
$project = $advinst.LoadProject("C:\Your Application.aip")
$project.ProductDetails.Version = "2.0.0"
$project.ProductDetails.ProductCode.GenerateAll()
$project.FilesComponent.AddFileS("APPDIR", "C:\Desktop\test.txt")
$project.Save()
When you want to edit an existing project, just use the LoadProject command.
To change the product code you can check all the commands here: ProductCode PowerShell Automation.
You can find more information and code example in our User Guide: PowerShell Automation
You can also have a look on our video: PowerShell Automation video tutorial.
Hope this helps! If you have any other questions, please don't hesitate to contact us.
AI_New_User
I checked PowerShell Automation but didn't see the code to set Builds as in (Package Definition > Builds > Builds > Settings > Builds)
In the example, how do I pick EITHER DefaultBuild or Build (not both) in Powershell?
Unfortunately, we do not have command line (automation) support for this setting.
I have added this improvement on our TODO list and it will be included in the future.
Thank you for your suggestion!
However, I have sent you over the email an RC Version which implements this. You can test this version and let us know if everything works as expected.
