the gridlock
How to add registry 32bit on system 64bit?
Tue Oct 19, 2021 4:08 pm
Hi admin,
My computer's using win64bit, autodesk app 64bit .
I'm creating a plugin that automatically loads the plugin when the app starts.
To do this I need to add the registry to this path (from the developer's guide):
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Company\...\...\...\Applications
If I set it up using the regular registry in the advanced installer it will add
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Company\...\...\...\Applications
How do I change this?
I hope to hear from you soon.
If this is not customizable I would like to be able to add both paths at the same.
Thank you!
Contact:  Website
Re: How to add registry 32bit on system 64bit?
Wed Oct 20, 2021 9:19 am
In order to achieve this, please have a look on the following reply from another thread which debates a similar issue:
Install registry entries (both 32 & 64 bit)
Also, you can check our How to install different registry entries based on the Operating System (32/64-bit) article.
Hope this helps! If you have any other questions, please don't hesitate to contact us.
the gridlock
Wed Oct 20, 2021 2:00 pm
Hi Liviu,
This seems to be exactly what I needed.
I've seen it but I haven't tried because the 64-bit component's name is confusing.
I'll try it and get back to you later.
Wed Oct 20, 2021 4:14 pm
We are glad that is what you were looking for.
Please let us know if you encounter any issues during the implementation and we'll gladly assist.
