efultz
Installer Doesn't Think I have Admin Privs
I have an install process - until recently have used v12 - now I am upgrading to v18.8. I built the MSI but when I run it says I have to have admin rights to run the installer. Thing is - I have admin rights. What is the installer looking at where it does not think I have admin privs?
Re: Installer Doesn't Think I have Admin Privs
I am not quite sure I fully understand the issue here.
If possible, could you please give me some more details (attaching a screenshot of the encountered error would help here as well)?
efultz
The issue I am seeing is attached. My account has admin privs but when I run the installer the first thing it does is tell me I need admin privs
Screenshot 2021-10-22 102601.png (63.71 KiB) Viewed 14850 times
Hello Edward,
That might be happening due to the "Run only if current user is Admin account" option being checked in the "Launch Conditions" page.
I have checked this on a test machine where the user is an administrator and everything worked as expected. Could you please double check this once again and make sure the user is actually an administrator?
If you do not actually have this requirement (i.e. the user being an administrator), you can disable the option.
efultz
attached is screenshot showing my domain account in the administrator group - my install updates service and registry so admin is needed to accomplish those tasks. But since I am already admin why doesn't the installer believe it?
Screenshot 2021-10-22 112727.png (12.99 KiB) Viewed 14841 times
efultz
Attached is log from running the installer - hope this helps
MSIbe55e.LOG
(86.23 KiB) Downloaded 822 times
efultz
Where is the installer looking to determine whether I have admin privs?
Hello Edward,
It looks like the "Run only if current user is an Admin account" launch condition verifies whether or not the package is elevated at the moment this is tested for.
This means the user might be an administrator but the package did not yet elevate, meaning the launch condition will fail.
Could you please elevate the setup package and let me know if this is still reproducible?
If you have an MSI, you can elevate it as it follows:
- open an administrator command prompt
- launc the MSI as it follows:
msiexec /i <path_to_msi>
If you have an EXE, you can elevate it as it follows:
- right click on the EXE --> "Run as administrator"
Additionally, if you build an EXE, you can force the above by going to "Install Parameters" page and checking the "Run as administrator" option.
