yawar.k
Getting Build Error while installing setup in Citrix Environment
I have prepared the build for one for my VSTO project, we need to add some folders in Appdata/Roaming Folder every thing seems to be working fine in normal installation but when one of my client is trying to install it in there citrix's environment we are getting below error.
I had also attached the Folder Premission to that we can identify the issue.
Can u please help me out with this error i am not able find what is the root cause of it
Re: Getting Build Error while installing setup in Citrix Environment
I'm not really sure why this happens.
Can you please send us the .AIP (project file) and an installation log when this problem happens, by email to support at advancedinstaller dot com so we can further test and investigate this?
You can create an installation log by launching your setup package with a command line like this:
msiexec /i setup.msi /L*V installLog.txt
when using an MSI package type, or a command like this
setup.exe /L*V installLog.txt
when using an EXE package type.
