efultz
Where to define in Jenkins
The UI for the newest version of Jenkins is considerably different from the older version. I am trying to find in the new Jenkins where to define the path to the advanced installer.
The options available when adding installer is only the following:
Extract *.zip/*.tar.gz
Install from advancedinstaller.com
Run Batch Command
Run Shell Command
I already installed advanced installer on my machine so I just want to point to that with the path as we were able to do with the older Jenkins. I feel I am missing something fundamental here - I set up to use Install from advancedinstaller.com but I get this error:
FATAL: caphyon.jenkins.advinst.AdvinstInstaller$InstallationFailedException: Failed to extract Advanced Installer from https://www.advancedinstaller.com/downl ... dvinst.msi. Error C:\Windows\system32\config\systemprofile\AppData\Local\Jenkins\.jenkins\tools\caphyon.jenkins.advinst.AdvinstInstallation\18.8
Re: Where to define in Jenkins
Hello Edward,
By default, when adding the "Advanced Installer" as a tool in Jenkins (under "Global Tool Configuration")
Advanced Installer will be scheduled for download through the "Install automatically" option.
Basically, that tells Jenkins to download Advanced Installer everytime a job is running.
If Advanced Installer is already installed on the machine, we should uncheck that option and then we will need to input the home directory of Advanced Installer, as it follows:
efultz
Thank you - this helped - I had to uncheck the install automatically and then I was able to specify where to find AIP
You are always welcome, Edward!
Glad I could help.
