luanvieiralima
The CAB file size is limited to 2GB
Hey guys.
First I would like to apologize for English. I used google translator. I'm new to the forum.
I have a large project to create in advanced, but the same error message is always displayed.
I made a print of the configuration I'm using, and the size of the folder I'm creating in the project.
Error message:
The CAB file size is limited to 2GB, you can`t have more than 64K files in a CAB and you can`t compress files that are larger than 2GB
Version:
Advanced Installer 16.5
Folder Size:
Advanced configuration:
Re: The CAB file size is limited to 2GB
This happens because the Operating System does not support CAB files larger than 2GB and thus, no single MSI larger that 2GB can be created.
Advanced Installer supports packing files larger than 2GB only if the "Place files unpacked next to the MSI database" option or LZMA compression is used.
With that being said, you can check the "Archive installation files using LZMA compression" option in the "Builds" page.
Windows Installer has its limitations when it comes to managing large file installation. We’ll explore the available options for building installers with very large resources.
Before diving into, let’s summarize the current MSI limitations. The MSI utilizes CAB (Cabinet) files as storage containers for the files it includes.
  • Cab Maximum File Size: The maximum size of a CAB file is 2 GB. This limitation is imposed by the CAB file format itself.
  • Installer size: The MSI with resources inside cannot exceed 2 GB and EXE with resources inside cannot exceed 4GB. This is a Windows limitation.
Here's the Authoring Installer for Large Resources Overcoming MSI Size Limits (from a developer perspective) article that debates this subject.
