truejegor
Removе by UpgradeCode
Hello!
Please help me with my problem. I am doing the assembly in .msi. I need to call the uninstallation of my program by the update code. I found a similar solution in this thread: viewtopic.php?t=12297 . It almost helped me, but there was a problem. When I try to uninstall any program by this code (without formatting and flipping, reverse), then it is uninstalled without problems, but when I try to uninstall the MY program that I built, I get this:
(Translate: Are you sure you want to uninstall this product?)
And then this:
Here's an example in cmd:
msiexec.exe /x {14361018-38E1-4A92-A787-78C1A1464AFD} //producCode - done
msiexec.exe /x  {B3EAE680-B925-42D7-9E67-4746FA64BCB6} //UpgradeCode
Are you sure you want to uninstall this product? and this:
(Translate: This action is only allowed for installed products:)
msiexec.exe /x  {086EAE3B529B7D24E9767464AF46CB6B4B6} //reverse UpgradeCode - 2 picture
msiexec.exe /x  {810163411E8329A47A78871C1A64A4DF} //reverse ProductCode - 2 picture
I also tried to uninstall the program using the UpgradeCode, which I specified in the advanced installer, but I get the same error, although when I run the uninstall using the product code, everything goes without problems.
I want to do this without adding new key and new value to the registry via the registry tab in AI.
Thanks in advance for your reply.
Re: Removе by UpgradeCode
Unfortunately, I'm afraid that it might not be possible to do the uninstallation using the UpgradeCode.
First of all, please note that the UpgradeCode can be the same for multiple setups (e.g. if you install v1.0, v2.0 side-by-side).
The only way to uniquely identify a product is through the ProductCode, therefore I would suggest using it to uninstall your product.
You can have a look over the following article, where it states that msiexec expects the ProductCode to be passed when used with the /x command line.
Command-Line Options
