Amin-egn
Default installation folder in advanced installer
I wanna change default installation path in advanced installer v18.7, from C:\myApp to another volume like D:\myApp or E:\myApp and I used "Search", and set property to D:
it worked but it doesn't show D:\myApp (just show D:), and when target computer doesn't have D:\ it shows E:\APPDIR
What should I do?
Re: Default installation folder in advanced installer
I am assuming that you are also setting the APPDIR property according to the search.
Your search only returns the drive letter (i.e. D:\) and therefore the encountered behavior is normal.
If you would like to set it to D:\MyApp, you should add the [ProductName] property when setting the APPDIR property, assuming "MyApp" is the name you define in the "Product Details" page --> "Name" field.
Amin-egn
Hello Catalin,
Thanks for your reply, but it didn't solve my problem.
myApp is a place holder.
Indeed I want to setting installation path to non-boot drive (actually C:\ always is boot drive) so it must install on the other ones like D:\ or E:\ or etc.
I attached some screen shots to explain more.
In Sreenshot(21), my computer hasn't drive D:\ and default path set to E:\APPDIR.
Appreciatively.
Screenshot (21).png (899 Bytes) Viewed 17905 times
Screenshot (17).png (46.15 KiB) Viewed 17905 times
Screenshot (16).png (60.55 KiB) Viewed 17905 times
Amin-egn
Hello Catalin,
Appreciatively.
First of all, please note that the "Application Folder" field from the "Install Parameters" page is actually linked to the APPDIR property.
Basically, the APPDIR property will take the value of that field.
Here is how you could achieve what you want, in a different manner.
You can leave the "Application Folder" field to have the default value, e.g.:
[ProgramFilesFolder][Manufacturer]\[ProductName]
In "Dialogs" page, select the "FolderDlg" and under "Init Events" tab, add the following:
"New" --> "Set installer property value"
Property: APPDIR
Argument: [VOLUME_D]MyApp
Condition: VOLUME_D
Now please repeat the steps above after creating another search for the volume E, e.g.:
Property: APPDIR
Argument: [VOLUME_E]MyApp
Condition: VOLUME_E
This way, the APPDIR will be set to either D:\MyApp or E:\MyApp.
The only problem I see here would be if both drives exist on the machine. This way, the APPDIR will always be set to the second option (because this will overwrite the previous one).
Amin-egn
Thank for your guidance, My problem solved.
One more question :D
I wish to display myApp end of the path wherever user select.
I mean that user wants to change drive and folder for example from default path (D:\myApp) user wants to install on F:\ProgramFiles, My installer
shows F:\ProgramFiles (install on F:\ProgramFile\myApp), I wish it shows F:\ProgramFiles\myApp.
Appreciately.
Amin-egn
Hello again,
How to check available space on drive ?
I took a look on the Init Events conditions and found OutOfDiskSpace.
I added it like this.
Property: APPDIR
Argument: [VOLUME_D]myApp
Condition: VOLUME_D AND (NOT OutOfDiskSpace)
but it had no effect.
Is there other way to automatically switch to next consider drive (not-boot and has available space) after drive C ?
Best Regards.
You are always welcome! Glad I could help.
In order to do this, you can go to "Dialogs" page, select "FolderDlg" dialog and add on it the "Volume Cost List" control.
In order to achieve this, you can proceed as it follows:
- go to "Dialogs" page
- expand "FolderDlg" dialog
- select "BrowseDlg"
- select the "Ok" button
- under "Published Events", add a "Set property" event as it follows:
Property: APPDIR
Argument: [APPDIR]MyApp
Condition: <leave unchanged>
This way, after the user selects the path through the "BrowseDlg", the "MyApp" will automatically be appended to APPDIR.
Amin-egn
Thank you so much.
Glad I could help.
