Using AI 12.7.2
Need to enable/install the .NET, WCF, HTTP Activation on Windows 2012, 2016 and 2019 servers.
The powershell command to do this is: Install-WindowsFeature NET-WCF-HTTP-Activation45 and i've tested this at the Powershell command line for all 3 versions of windows server successfully.
I've added a custom action - Run Powershell inline script and pasted in my command below.
Set-ExecutionPolicy -ExecutionPolicy Bypass -Scope CurrentUser
Enable-WindowsFeature NET-WCF-HTTP-Activation45
When i build and run the installer on a server the installer fails with: The term 'Enable-WindowsFeature' is not
recognized as the name of a cmdlet, function, script file, or operable program.
Ian
