jusvu
Target dir bug
Hi! The default target dir in the app is [ProgramFilesFolder][Manufacturer]\[ProductName]. If I want to change the default dir, it will not be changed in the aip file (it adds MultiBuildTarget instead).
If I want for example this directory; [ProgramFilesFolder][Manufacturer], the aip file content is:
<ROW Action="SET_APPDIR" Type="307" Source="APPDIR" Target="[ProgramFilesFolder][Manufacturer]\[ProductName]" MultiBuildTarget="DefaultBuild:[ProgramFilesFolder][Manufacturer]"/>
and the app will be istalled in the wrong directory. If I manually edit the aip file, like this:
<ROW Action="SET_APPDIR" Type="307" Source="APPDIR" Target="[ProgramFilesFolder][Manufacturer]"/>
Then the installation is right.
Re: Target dir bug
This happens if you don't change the target build in the "Install Parameters" page.
Can you please select the desired build and let me know if the problem persists?
jusvu
Re: Target dir bug
I have only one target build, DefaultBuild. So I cannot change it. I just would like to change the target directory.
Re: Target dir bug
This is quite strange.
The MultiBuildTarget value appears only when you create multiple builds.
You can test this by creating a new project, when you have a single build the line is:
<ROW Action="SET_APPDIR" Type="307" Source="APPDIR" Target="[ProgramFilesFolder][Manufacturer]\[ProductName]">
Now if you add another build and open the project you can see that the MultiBuildTarget was added:
    <ROW Action="SET_APPDIR" Type="307" Source="APPDIR" Target="[ProgramFilesFolder][Manufacturer]\[ProductName]" MultiBuildTarget="DefaultBuild_1:[ProgramFilesFolder][Manufacturer]"/>
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this?
jusvu
Re: Target dir bug
I sent you two AIP files. One before changing the Application Folder and another AIP after changing.
Here are the repro steps:
1. Create a new project without changing the Application folder. Now the folder path is [ProgramFilesFolder][Manufacturer]\[ProductName]
2. Check the aip file, there’s now
<ROW Action="SET_APPDIR" Type="307" Source="APPDIR" Target="[ProgramFilesFolder][Manufacturer]\[ProductName]"/>
3. Manually edit the Application Folder in Advanced Installer Install Parameters view, type for example: [ProgramFilesFolder][ProductName]
4. Check the aip file, there’s now
<ROW Action="SET_APPDIR" Type="307" Source="APPDIR" Target="[ProgramFilesFolder][Manufacturer]\[ProductName]" MultiBuildTarget="DefaultBuild:[ProgramFilesFolder][ProductName]"/>
Check the target menu: only one target (DefaultBuild) is available
Re: Target dir bug
