McKool
Change a default project string
Hello all,
Advance Installer v 17.1.2
Windows 10 x64
I'm trying to change the message being shown, when a launch condition is not satisfied. My installation uses two languages, english (default) and German. I'm able to change the german translation by using the UI, Project/Translation/Project Strings tab.
My problem is that I also want to adjust the english text, but in the mentioned tab, the english text is disabled and cannot be modified.
Default project string
I tried already to modify the table "LaunchCondition" but in this case, I always get the text of that table (english), indifferently of which language is being used at installation time.
LaunchCondition Table modification
Another thing that I have tried was to include the Localization Ids for the launch conditions in my own dictionary, since the help states that strings are searched by their localization identifiers in the dictionaries in a descending order:
Custom dictionary on top
Custom dictionary extra code:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<DICTIONARY type="multilanguage">
  <!-- AI defaults -->
  <ENTRY id="AI.LaunchCondition.NoSpecificNT">
    <STRING lang="de" value="Diese Version von [ProductName] benötigt Windows® 10 oder höher."/>
    <STRING lang="en" value="This version of [ProductNameShort] requires Windows® 10 or higher."/>
  </ENTRY>
  <ENTRY id="AI.LaunchCondition.NoSpecificNT64">
  </ENTRY>
  <!-- ActionText table -->
but this also not worked. Can someone please tell me how can I change these texts on the default language so that on an english system the text "This version of [ProductName] requires Windows® 10 or higher" is shwon and on a german system the text "Diese Version von [ProductName] benötigt Windows® 10 oder höher." is shown?
Thanks in advance.
Re: Change a default project string
Changing the text of the launch condition directly in the "Table Editor" works only when you have a single-language project.
Since in the "Project Strings" tab you cannot change the English description, the only solution is to edit the string in the .aip file with a text editor, for example notepad:
After editing this, you can see that the description is changed in the project:
McKool
Thanks a lot! it works.
I thought that all text were coming from a dictionary. Didn't know that these were placed in the project file.
You're welcome!
I'm glad that now everything works as expected.
