Dina.Kebir
Installer UI Font Size Problem on High DPI Screen
I run our installer on laptop with regular dpi screen, there is no issue with the font size, however, when running it on high dpi screen, for example my laptop (125% recomended), the font on the installer is too small.
How can i fix it to be flexible with diffrent dpi on our client's laptop ?
N.B: there is no issue with images and icons, it works perfectlly fine. the issue is only in font size.
Thank you in advance.
exemple
exemple
Re: Installer UI Font Size Problem on High DPI Screen
I was not quite able to replicate this behavior on my end.
Can you please send us the .AIP (setup project) file by email to support at advancedinstaller dot com so we can further test and investigate this? If it contains confidential information you can send us a small test project which reproduce this behavior.
If possible, could you please give me some more details about how to reproduce this issue (perhaps a test-case which I can follow), on which Operating System that happened and also the Advanced Installer version?
