pforsbom
VS2022 and AI 18.9 - Target framework not supported
Hi
When I open a Visual Studio solution that has Advanced Installer project I get a message telling me that "Target framework is not supported".
If I select "Update target to .NET Framework 4.8" the AI project is unloaded from the solution. If I try to reload the solution I am asked the same message as before.
I am using Visual Studio 2022 (17.0.1) with Advanced Installer 18.9
I am using the Advanced Installer for Visual Studio 2022 Extension.
Re: VS2022 and AI 18.9 - Target framework not supported
I am not quite sure I understand what the issue is here.
As stated in the message, your project is currently targetting .NET Framework 4.0 which is no longer supported.
To avoid this, you can select to update to .NET Framework 4.8, which is the recommended approach.
pforsbom
Hi
I have tried clicking "Update the target to .NET Frawork 4.8" but that does nothing.
Technically there is nothing in the aiproj file or aip file that indicates TargetFramework.
I have also tried adding a new AI project to a new solution. I selected .NET Framework 4.8.
But when I save & re-open the solution I get the same behavior.
After this the AI project is unloaded.
pforsbom
Hi
I just want to add an observation: I am monitoring the sln, aip and aiproj files - when I try to upgrade the target framework no updates are written to any of the files.
Are you by any chance using Windows 11 as your Operating System?
We have run some tests on Windows 10, without being able to reproduce this. However, one of my colleagues was testing something last week related to the extension on Windows 11 and encountered the same behavior.
Please disregard my last thread, as I managed to reproduce this on Windows 10 as well.
I will forward this to our development team for further investigations.
pforsbom
Hi
Great you where able to reproduce :D
Yes, I am using Windows 11.
Thank you! I will update this thread as soon as I will have more information.
Hello Peter,
Please note I have sent you via email a possible fix for this issue.
AlbertoVieira
Catalin wrote: ↑Wed Dec 08, 2021 10:25 am Hello Peter,
can you post here? i`m also having this problem.
Hello Alberto and welcome to our forums,
Unfortunately, this has not yet been fixed.
Please disregard my last thread as that was actually a fix for another issue.
As soon as I will have a resolution to this, I will let you know as well.
Hello guys,
Please note I have provided a possible fix for this issue via email.
Roberto
I got the same issue on Windows 10, Visual Studio 2022
Thanks and regards,
Roberto
Hello Roberto,
Please note that I have sent you via email a possible fix for this issue.
Roberto
Liviu wrote: ↑Fri Dec 10, 2021 5:16 pm
Hello Roberto,
Hello Liviu,
I received your email and followed your instructions.
Now the extension works fine.
Question: further updates of the extension will be released automatically by your systems?
Thanks and regards,
Roberto
